Green glow only on color scan
  • glimmer1980
    • Aug 2014
    • 105
    1646043501752_20220223_121720_000011053264.pdf1646043501752_20220223_121720_000011053264.pdf1646043501752_20220223_121720_000011053264.pdfgreen glow.JPG
    Hello,
    We have a MX-2614 at the customer site. When we scan a B/W all is ok. When we scan in color, the scan has a green glow over it.
    Has anyone exprecienced this before?
    Regards,
    Ramon
  • OlliK1969
    • Nov 2016
    • 310
    Re: Green glow only on color scan
    Hi
    Have you cleaned the mirrors, lamps and the CCD?
    White balance performed ??
    • ntbann
      • Jan 2012
      • 628
      You may need to run the SIT chart sim.
      • Nachoman4life
        • Oct 2007
        • 212
        Yes I have seen something like this on an ARBC320, many years ago, I had a mouse pee damaged Color ASIC, on the ICU (now the SCU pwb). Yours may not be mouse related, possible a staple fragment, or some thing else conductive made its way to the board, or just chip failure.. Color scans were a perfect blue background, L to R, and F to R. Color copies were ok. Only color scans were affected. I would try the SCU Pwb first, a somewhat easy change, the main scanner color ASICs are on the SCU. Second I would try the Mother PWB, it acts like a 4 way stop between the SCU, MFP, PCU, and LSU PWB. Third print controller (MFP). Be very careful during you EEprom swaps. If the SCU change works, if the color copy/scan balance is off, then Use SIT chart ADJ.
        Where the heck is my spring hook?
        • spanky
          • Sep 2012
          • 468
          Do internal prints like sim 64-5 also show this?
          • glimmer1980
            • Aug 2014
            • 105
            Internal prints are ok. The strange thing is that when we make a copy the print is ok, but when we make a scan to email there is a green glow. I would expect that when i would make a copy the same problem would occur.
            • mansart
              • 852
              On the newer models you can adjust scan quality, to include bumping up green.
              So I would suspect the older machines were probably adjustable as well but only through SoftSwitches.
              I would print out a 22-6 from the machine in question then compare a 22-6 from a similar machine.
              Softswitches that print out as "black text on white" are default
              Softswitches that have been changed will print as "white text on black"
              • ZachHarbour
                • Jun 2021
                • 23
                I like the idea of checking for this. I've had all kinds of issues related to staples or paperclips making their way onto the boards. Thankfully that's something that is very easy to check.
                Best of luck
                Zachary Harbour
                Hogland Office Works
                zach@hoglandcopiers.com
