I have a virtually new (1,700 SPF scans) doc. feeder from a MX-4070V that I want to put on a MX-M4070 (Mfg dates are 1 year apart) that has a blown DSFP control PWB (paper clip fell onto the board during use), and is physically worn out (338,000 document scans). As I recall, I did something similar once, and discovered that only the actual control boards & interface cable to the copier are different but all the other connectors to the control board are the same internally, with the exception of that interface cable. I want to put a new/repaired DSPF control board with the corresponding correct interface harness into the MX-4070V SPF, and pop it on the monochrome machine. Has anyone experience doing this?
