AR-M300u maintenance required?
  • ezzysi
    • 77
    Hi chaps, i've been given this call from one of our customers.. we don't do sharp normally so i've no idea!!
    Apparently it come up with "mainenance required" as soon as its powered up and wont do anything else. Does this machine lock out when it needs a service or do we think theres something else amiss?
    Whats involved in doing the service and resetting the count?
    A million humble thank-yous to anyone who can help
    Si
  • vlad_robas
    • Oct 2006
    • 225
    hi,
    i don't know that machine but from 351 and others that seems like a setting to stop when maintenance life is over 100k probably
    26-38
    Purpose Setting
    Function
    (Purpose)
    Used to set CONTINUE/STOP of printing when
    maintenance timing is over and the count value
    reaches 110% of replacement timing (life).
    Section Other
    Item Specifications
    default is 0 so sombody who had worked on that machine wanted to be sure he is called and make few buck's over that maintenance setting
    • vlad_robas
      • Oct 2006
      • 225
      u have to enter in 26-38 and modify from 0 to 1 to continue printing/copy
      with 22 1 u can see where the counters are for each part
      Used to check the print count value in each
      section and each operation mode. (Used to check
      the maintenance timing.)
      and if u perform the maintenance replacing what is need u have o reset the
      24-4,5 and 7
      • vlad_robas
        • Oct 2006
        • 225
        ∗ Entering the simulation mode
        1) Copy mode key ON → Program key ON → Asterisk (*) key ON
        → CLEAR key ON → Asterisk (*) key ON → Ready for input of
        a main code of simulation
        2) Entering a main code with the 10-key → START key ON
        3) Entering a sub code with the 10-key → START key ON
        4) Select an item with the scroll key and the item key.
        5) The machine enters the mode corresponding to the selected
        item.
        Press START key or EXECUTE key to start the simulation
        operation.
        To cancel the current simulation mode or to change the main
        code and the sub code, press the user setup key.
        ∗ Canceling the simulation mode to return to the normal mode
        1) Press CA key.
        • ezzysi
          • 77
          Thats great info vlad, just what I need.
          Have a virtual beer on me!
          • vlad_robas
            • Oct 2006
            • 225
            i prefer JD but beer works too
