Sharp 70/71 series maintenance code suppression?
  • sl0bster
    • Jun 2015
    • 1
  • Sharptech0892
    • Aug 2011
    • 79
    • nanohitmen
      • Apr 2019
      • 115
      Re: Sharp 70/71 series maintenance code suppression?
      Same run till they break here, but for god sake's DO NOT RESET DRUMS/MK's , it destroys the quality and the pages will come out looking greyed out.
      • ZOOTECH
        Senior member of CRS
        • 3375
        I found this info on line by mistake, not really sure how I got there.
        Stop Maintenance Counter: Set 21-1 to 999 (free)
        Stop Drum Maintenance: Set 55-3 Switch 22 Bit 6 to 1
        Stop Developer Maintenance: Set 55-3 Switch 27 Bit 2 to 1
        Stop Primary Transfer Unit Maintenance: Set 55-3 Switch 27 Bit 4 to 1
        Stop Secondary Transfer Maintenance: Set 55-3 Switch 27 Bit 5 to 1
        Stop Fusing Unit Maintenance: Set 55-3 Switch 27 Bit 3 to 1
        This is in the soft switches, not SIMS.
        I have not tried this, so I canโ€™t guarantee the outcome, nor take credit.
        Use at your own risk.
        • mxm
          • Feb 2011
          • 37
          works on nearly all Sharp machines.
          21-1 set to 999 for TA
          55-3 sw 22 bit 6 from 0-1 cancels DC,DM,DY
          55-3 sw27 bit 2 from 0-1 cancels VK
          55-3 sw27 bit 3 from 0-1 cancels FK1 & 2
          55-3 Sw27 bit 4 from 0-1 cancels TK2
          55-3 sw27 bit 5 from 0-1 cancels TK1
          55-3 sw34 bit 1 from 0-1 cancels TK3
          55-3 sw34 bit 2 from 0-1 cancels MCK, MCC,MCM,MCY
          • nanohitmen
            • Apr 2019
            • 115
            Thank you you glorious tech, worked like a charm
            • blackpanther
              • Nov 2017
              • 16
              This may also help:
              SIM55-01 SWITCH9 BIT8 set on:1 Set Maintenance Cycle to prints instead of revolutions/turns
