Sharp MX-2614 Tray 2 Issue
  • BatteriesNotIncluded
    • May 2022
    • 4
    Hey everyone.
    First off, forgive my naivety with printers!
    I just acquired a Sharp MX-2614. Unfortunately, the bottom section (the trays and wheels) got dropped at some point. The printer works great, but it’s not recognizing Tray 2 (A3). It’s just not showing up in the options.
    I’ve compared the two drawers (A4 & A3), and the inside of the machine, and nothing seems obviously amiss.
    One thing of note, I noticed the two parts of the machine are linked by any cables. It just sits on the the four corner stubs. Is this normal?
    Can anyone advise what to look for or double check?
    thank you in advance!
  • Londo
    • May 2021
    • 15
    Re: Sharp MX-2614 Tray 2 Issue
    If your able to select second cassette in copy mode everything is ok, on print driver, first tab from right , autoconfiguration and it should shows you all options you have , select that one with pointed and it ok.
    If your unable to select second cassette on copy mode, check connector on the back.
    Sorry for my English but is not my native language
    Londo
      • May 2022
      • 4
      • Prints Charming
        • Aug 2019
        • 189
        If you can't see the lower trays, check the desk > engine interface harness.
        Take the small cover off the back of the engine, check the 2 harnesses are correctly installed and the small horizontal piece is removed from the cover.
        Power up and test. That's the first thing to check anyway. Please update us with photos of the damage caused by the unit being dropped.
          • May 2022
          • 4
          Prints Charming, that was it!
          The harness must have popped out (perfectly without bending the pins, thankfully) when the unit was dropped. I’m told it was picked up without knowledge it is a two piece machine. The harness tucked itself away into a place that did not make it obvious a harness was even there.
          Your post solved the issue immediately. Thank you very much for your help.
          Out of interest, if I ever needed a spare part, where best to source from in the UK? Additionally, are there any toner suppliers you recommend?
          Additionally, thank you Londo. You were also right — I just didn’t know what connector I was looking for until Prints specified.
          • Prints Charming
            • Aug 2019
            • 189
            Very good. Well done.
            Please just check the 4 corner screws & locking plates are correctly installed. The engine & desk unit should not come apart when lifted. There's no way the desk harness can be pulled off the connector if the locking plates are installed.
            Parts and toners.....always use genuine OEM if possible. Contact a nearby service agent to point you in the right direction.
              • May 2022
              • 4
