Set Default Scan Credentials MX-4071
  • rthonpm
    • Aug 2007
    • 2859
    I'm primarily a Ricoh guy, but one of my customers has one of these from their parent company. I'm looking to set it up for scan to folder using an AD service account but I don't see any option in the web interface to set a default sender for scanning.
    With about 30 entries to set up between project and user folders, I'd rather not have to add, and later update, the service account password to every entry.
    Is there anyway to set a single credential set that scan to folder uses unless manually entered in the address book for a specific entry?
    Sent from my BlackBerry using Tapatalk
  • mojorolla
    The Wolf
    • 2626
    Re: Set Default Scan Credentials MX-4071
    Sharp Copier Active Directory Integration - Skelton Business Equipment, a Division of Platinum Copiers (equipmybiz.com)
    • rthonpm
      • Aug 2007
      • 2859
      Thanks, though it will not really work for the customer as they're just looking to authenticate a single account as a back end authentication method instead of authenticating users to access the device.
      • Prints Charming
        • Aug 2019
        • 189
        Create the AD account to be used for authentication. If you need help on AD setup, let me know. I have alot of documentation on this.
        System Settings > Image Send Settings > Scan Settings > Default Address > Default Address Settings: Enable.
        System Settings > Image Send Settings > Scan Settings > Default Address > Add Selected: Apply Home Directory of the user for login. Press Submit.
