The 2nd transfer belt is not turning which is causing an accordion jam. I marked both the belt and the drive gear and neither the belt or the gear is turning. I believe it could be the motor, but I welcome a second opinion. Also if there is a way to perform a check of the motor in the simulation mode, that information would be deeply appeciated.
Sharp MX101N - 2nd transfer belt not turning.
