only use TLS 1.2 on MX3070
  • glimmer1980
    • Aug 2014
    • 105
    Hello,
    At a customer site they have 1x MX3070N and 1x MX4071. Within the settings of the MX4071 there is an option where you can check "only use TLS 1.2". This option is nowhere to be found on the MX3070N.
    Is there a way on the MX3070 to use only use TLS1.2? Would the "Level of Encryption" be a way to make the machine more secure?
    Regards Ramon
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • copiertec
      • Jan 2016
      • 2211
      Re: only use TLS 1.2 on MX3070
      We always put ssl settings to medium, I believe that enables tls 1.2.
      • spanky
        • Sep 2012
        • 468
        There is a firmware update to install the TLS 1.2 on the 3070.
        • copiertec
          • Jan 2016
          • 2211
          You would think that with series, tls 1.2 or higher would be standard. The things that make you scratch you head.
          • spanky
            • Sep 2012
            • 468
            The first batch of this model was released over 5 years ago, before the TLS 1.2 was used.
