Sharp MX-M654 and M465 Job accounting list
  • stuckwithit
    • Jan 2015
    • 12
    Haven't worked on Sharp in a while but need to get the accounting codes out these machines for another product. I'm sure there is an Admin login and can it print out the report with name and codes? Thanks
  • Joker
    • Sep 2021
    • 12
    Re: Sharp MX-M654 and M465 Job accounting list
    You have to enter simulation mode and do the 22-6 simulation to get information from the machine, I don't know if this is what you need.
    • stuckwithit
      • Jan 2015
      • 12
      No that is machine settings, I need job accounting codes that the end user puts in for individuals to access the machine to keep up with the amount of copies used. Schools use this feature a lot for restricting use by unauthorized usage. I'm sure there is an admin password to get into this setting.
      • mojorolla
        The Wolf
        • 2608
        Login to the webpage (Administrator / admin) and the setting you are looking for are under User Control
        • stuckwithit
          • Jan 2015
          • 12
          Where do you go if the copier is not connected? Is the login the same at keyboard?
          • mojorolla
            The Wolf
            • 2608
            Yes and still located under User Control
