Sharp AR6020DV
  • Abimotek
    • Feb 2015
    • 59
    [Jamming] Sharp AR6020DV
    Hello, sharp Ar6020, keep jamming as picture showed, but side tray doesn't jam, I try another tray unit same problem, pls solution
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp AR6020DV
    What jam codes are you getting? Are the Meter counts close to PM cycle?
    • Abimotek
      • Feb 2015
      • 59
      Re: Sharp AR6020DV
      It doesn't show code, after I press make 1 copy, it keep jamming, it indicate sign as attached picture. side tray okay no jam, only down tray jam. pls how to clear it or solution
      • georgereth
        • Jul 2009
        • 47
        Re: Sharp AR6020DV
        clean the rollers with sandpaper and no more jams i also do this on other AR machines and MXM machines
