Sharp mx-c300w prints but won't copy or scan
  • Rlucas2125
    • Sep 2022
    • 5
    Sharp mx-c300w prints but won't copy or scan. When trying to copy or scan it prints out a page with random lines.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp mx-c300w prints but won't copy or scan
    Does the scanner move? Does it happen through the ADF and off of the glass?
    Good luck
    Bil
    • Rlucas2125
      • Sep 2022
      • 5
      Good luck
      Bil
      Yes the scanner moves, light comes on and yes it happens through the ADF.
      • tmw
        • Dec 2013
        • 260
        Possibly the ccd went bad. Reseat the connections on the ccd and scanner boards first to see if it does anything. One of them may need replacement.
        • Rlucas2125
          • Sep 2022
          • 5
          Thanks! I will check these. Does anyone have a link to repair manual for this copier?
          • Ben Around
            • Apr 2012
            • 151
            i've had to replace the ccd assembly on this model/series before for the same problem. Checking the connections is a good idea, but I think you need to replace the ccd. It might be time for them to get a new machine. That model is pretty old.
            • Rlucas2125
              • Sep 2022
              • 5
              Thanks for the info! Do you know where I can locate a ccd?
              • Ben Around
                • Apr 2012
                • 151
                You can try Precision Roller.
                Sharp MX-C300W Scanner Unit, Genuine (K8115)
                • mloudy
                  • Oct 2015
                  • 791
                  They are out of stock at PR and at Sharp. 19 are expected to arrive at Sharp on 9/20 but they could all be spoken for.
                  • Rlucas2125
                    • Sep 2022
                    • 5
                    Thanks everyone for your help! I'll see if I can find one....
