sharp arm-450
  • DINGO
    • 661
    sharp arm-450
  • mtech
    • Mar 2007
    • 307
    Sounds like the scan resolution is set higher than the other ones not having the issue. Reduce the resolution.
    • DINGO
      • 661
      re
      mtech
      y just saw that, the only thing that y can about resolution in copy is in operator panel control the option "higt resolution scanner", and is in same conditons them the others, thats meen not choise this option.
      there are another option about resolution in copy the arm-450n?? or some configuration code??
      thanks
