Sharp MX-M623N Developer and Drum replacement service mode procedure
  • dantab1980
    DanTab
    • May 2015
    • 16
    [Misc] Sharp MX-M623N Developer and Drum replacement service mode procedure
    Haven't seen one of these in over 10 years and need to replace drum, charge unit, cleaning blade and developer. I don't have access to the service manual since we're no longer a Sharp dealership (now Kyocera) Anybody have access to the service manual for the proper procedure for which simulations to run upon start up?
    THANKS!!!!
  • WackyJack
    • Feb 2021
    • 82
    Re: Sharp MX-M623N Developer and Drum replacement service mode procedure
    THANKS!!!!
    First, in case you don't remember the sequence to get into service mode: # * C *
    Leave side door open until you enter 25-2
    Close side door
    Run 25-2 with toner installed. Press CA key when done. Machine should reboot
    Re-enter service mode
    44-2
    44-6
    44-26 Press CA key when finished to exit and machine should reboot again
    46-74 Be sure to touch OK at the end to register changes. When done, press the CA key to exit
    • dantab1980
      DanTab
      • May 2015
      • 16
      Thanks!!!!
