range_sub_m 93 MX-3050
+ More Options
Posts
  • bigdaddyooo
    • Dec 2014
    • 215
    I have a rebuilt TC1 unit with all mods and brand new belt giving this code on EVERY machine we install it in. I did a 44-2 and noticed that the only difference in both units that the 44-2 readings are
    *belt pcs r dif is 3 *belt regs f dif is 15
    NOW on nonfunctioning unit
    that is the only out of adjustment from functioning unit
    *belt pcs r dif is 12 * belt regs f dif is 46
    ANY IDEAS?
    Are you the police? "No ma'am, were musicians"
  • OlliK1969
    • Nov 2016
    • 312
    Re: range_sub_m 93 MX-3050
    Hi
    The transfer belt installed correctly? With the marking on the back of the device ??
    • bigdaddyooo
      • Dec 2014
      • 215
      Originally posted by OlliK1969
      Hi
      Absolutely and just for shites and giggles I tried it reversed...same issue
      • boutn
        • Jun 2016
        • 552
        Did you check if the revised tension springs are on the unit? Could be that the belt slips.
        • bigdaddyooo
          • Dec 2014
          • 215
          Absolutely. I said that it was fully modified in the 1st post.
          • bigdaddyooo
            • Dec 2014
            • 215
            UPDATE final.
            I replaced the brand new belt with another brand new belt and VIOLA it works. JEEEEEESH
