MX-B350P L4-14
  • bigdaddyooo
    • Dec 2014
    • 211
    MX-B350P L4-14
    question, in sim 10-4 when activated the service manual says "highlighted" when the toner motor sensor state changes. I have a little asterisk blinking next to it. Anyone ever see that and is that the "highlight"?
    Are you the police? "No ma'am, were musicians"
  • bigdaddyooo
    • Dec 2014
    • 211
    Re: MX-B350P L4-14
    UPDATE. final
    Just talked with Sharp and they have a 350P there. He tested it and results are the TM_COUNT does not highlight, the asterisk flashes when off and on.
    • jp74msj55
      • Oct 2014
      • 149
      Re: MX-B350P L4-14
      Originally posted by bigdaddyooo
      UPDATE. final
      I've had about 4 of these. replace the unit CCOVP0249QS51.
      Also have had bad sensor in unit and the timing gear broken before. Easy to replace!!!
      Good luck.
      • mloudy
        • Oct 2015
        • 784
        Re: MX-B350P L4-14
        Good luck.
        We keep these in stock and have replaced 7.
        • bigdaddyooo
          • Dec 2014
          • 211
          Re: MX-B350P L4-14
          Good luck.
          EXACTLY what I did and VIOLA...works fine..TY
