FN27 close front cover message
  • glimmer1980
    • Aug 2014
    • 105
    Hello,
    We have a MX6071 with a FN27 (internal finisher). We keep getting the message "close the finisher front cover", even though the cover is closed. I have tried swapping the cable that should sense that the cover is closed, but no succes.
    Does anyone had this problem before?
    Regards,
    Ramon
  • DavePo
    • Jul 2008
    • 305
    Re: FN27 close front cover message
    Have you verified that you are getting 24VDC at the switch? If missing you would get that message.
    • Prints Charming
      • Aug 2019
      • 189
      Go into Finisher Sensor Tests in Sim 3.
      Look for FNMSW1 and see if it actuates high/low when you open/close the front door. Issue will be broken sensor shutter on front door, or sensor inside the front cover.
      • Craigcul
        • Aug 2017
        • 70
        What I have found is just under the door cover is a metal spring plate that gets bent then it will show the door open when it is not.
        Sent from my SM-A715F using Tapatalk
