Sharp MX-B376WH error code E&-80
  • MAW
    • Mar 2019
    • 11
    Hi,
    I'm having a problem with a new copier a MX-B376WH the error code is E7-80 I follow the service manual advice, I have already checked and reset the connectors and replace the MFPC PBW I'm still have the same problem and I can't update the firmware because the error code comes back while the copier checking the firmware. Any help or ideals would be appreciated.
  • mansart
    • 852
    Re: Sharp MX-B376WH error code E&-80
    Have you tried firmware via CN (emergency) method?
    • mloudy
      • Oct 2015
      • 775
      We had a MX-B355W out of the box with a E7-80. Ended up being the Scan control pwb and not the MFPC pwb.
