mx 7040 stubborn E6-11 code
  • tmw
    • Dec 2013
    • 260
    Hi. I read all the other threads about this and checked the manual, but not seeing anything different. When I first looked at it, the duplex lamp wasn't lit so I replaced it. That appeared to fix it for a couple days then the error returned. I went back with an entire feeder hoping that would take care of everything. Still no luck. I updated the firmware and did the shading execution with no change. So far the only other thing I can think of left over is changing the scan board in the back. What do you think are the chances of this ? Is there something else I may be missing ? Thanks for your input.
  • dmary
    • Jun 2017
    • 20
    Re: mx 7040 stubborn E6-11 code
    Shading adjustment (Calibration) (DSPF mode)
    French technician since 1994. Thanks to Google Translator for helping me to make myself understood by you.
