MX-B467F (Lexmark XM1246) Light Prints and copies
  • travi
    • Jan 2008
    • 129
    I have an MXB467F that prints out light pages when printing from a computer and making copies. Faxes and internal test prints will print normally. I have checked and cleaned drum contacts. Checked toner installation. Updated firmware.
    Has anyone else seen this problem and what was your solution. Thanks
  • subaro
    • Oct 2010
    • 1274
    Re: MX-B467F (Lexmark XM1246) Light Prints and copies
    Bump up the print and copy density by 1 and check your results. I don't like that model. The 3250 is the ideal machine run, it's a good machine and workhorse.
    • mloudy
      • Oct 2015
      • 791
      Yes as said above it is as simple as moving the Darkness up 1 in the Copy, Copy Default settings. I do this on all mono Lexmark and Sharpmark MFPs.
