MX M4051 POD1_N Jam
  • akimikenji
    • Aug 2022
    • 3
    [Jamming] MX M4051 POD1_N Jam
    Hi, i am facing a problem where the paper will get stuck in the fusing and make the paper become a paper fan. By the way, this machine is new one, including the fuser unit. When i check the sim 23-2 it shows pod1_n jam. However when i change the paper to a4r no jam at all.Example.jpg
  • driving lots of miles
    • Jun 2016
    • 398
    Re: MX M4051 POD1_N Jam
    Have you checked the paper path for a bent or torn mylar?
    • akimikenji
      • Aug 2022
      • 3
      Yes i already check that mylar, maybe i need to double check if i miss that. Thanks ya
        • Jun 2016
        • 398
        I would look at the paper exit above the fuser and check if it has become unplugged or loosely connected as a next step.
        • dmary
          • Jun 2017
          • 20
          In some cases, ''H'' trouble codes may occur due to contamination or damage to the fuser assembly connector terminals.
          Fault code H2, H3 random paper jam
          The male connector on the oven deforms under the effect of heat causing poor contact between the Pins of the oven connector and that of the machine.
          Cause :
          Poor heat removal from the oven can cause the temperature to rise.
          temperature in the machine (the heat from the oven is discharged to the outside of the MFP by the
          fans)
          1) Only on the High volume range is there a fine particle filter
          Clogging of the filter and the fan can cause the internal heat to increase,
          this heat causing the plastic to deform.
          The UFP MX609UF filter kit filter must be changed at 300k copies on the HV range.
          On the Low volume range, there is no filter
          Check that the fan is not clogged.
          2) From Firmware version 0500z100 (MX-M4050), the management of the detection of a code
          breakdown "H" has been modified as well as the detection of the winding of a sheet of
          paper around heat roller causing H5-01 trouble code.
          Last Firmware MX-M4051 (04.10.z2 - 10/2022)
          Connector reference (without harness): DHAI-6410FCPZConnecteur CR4N.jpg
          French technician since 1994. Thanks to Google Translator for helping me to make myself understood by you.
          • akimikenji
            • Aug 2022
            • 3
            Update after i lower the fusing temperature no misfeed at all .By the way this machine use only 12,211 copies only, fuser still new .
              • Jun 2016
              • 398
              I would not have thought of this. It makes me think that High moisture content in the paper causing it to curl right out of the fuser and then doing the jamming as it is not going into the paper path correctly. It sounds like you have found a solution. Thanks
