Sharp mxm 266N
  • davebtech
    • Apr 2015
    • 176
    Sharp mxm 266N
    Anyone ever have issues on tls 1.2 firmware upgrade on this series with hard drives installed? Seems like the 301 dosnt work . Can the hardrives just be taken out to put in the 300 version 1.2? Thanks Dave
  • mloudy
    • Oct 2015
    • 786
    Re: Sharp mxm 266N
    When you install a HDD in this model it also came with a SD card. If you remove the HDD you would have to install a SD card with the original .imgc file on it.
    • davebtech
      • Apr 2015
      • 176
      Re: Sharp mxm 266N
      • mloudy
        • Oct 2015
        • 786
        Re: Sharp mxm 266N
        You will need one of the following:
        A new SD card ordered as a part from Sharp. Part# VHI0MFP00214C. You would need to verify this is the correct part #.
        or a new SD card (like a Sandisk) with an image copied to it from a known good non-HDD MX-M266N. We use the 32GB. Not sure if this if something you have done before using HDD Raw Copy tool??
        or a SD card from a donor MX-M266N that doesn't have a HDD in it.
        Before you pull the HDD I may have a M266N with a HDD kit installed that I can pull from the warehouse to see if I can install the 301 firmware on and see if I have an issue.
        • mloudy
          • Oct 2015
          • 786
          Re: Sharp mxm 266N
          I don't have any MX-M266N, only a bunch of M264N.
          • davebtech
            • Apr 2015
            • 176
            Re: Sharp mxm 266N
            • Craigcul
              • Aug 2017
              • 70
              Re: Sharp mxm 266N
              HI the firmware of the MX-M266 with harddisk is different to the firmware without harddisk the sd card is also different
              • davebtech
                • Apr 2015
                • 176
                Re: Sharp mxm 266N
                • Craigcul
                  • Aug 2017
                  • 70
                  Re: Sharp mxm 266N
                  Hi the latest that I can see from my dealer is version 302
