MX6070N Application Portal
  • boutn
    • Jun 2016
    • 537
    is it possible to activate Application Portal on an MX6070N?
    I would like to scan directly to Sharepoint if possible...
    Or does this only work on the Phoenix2/Griffin2 series?
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Re: MX6070N Application Portal
    Looks like it can be done, check page 21 on the cloud handy guide.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • boutn
      • Jun 2016
      • 537
      Does anyone have an idea if the Sharepoint app works when MFA/2FA is enabled on O365?
      on the MX3071, it works, but on the MX6070N, you get login failed, no popup or nothing.
      • boutn
        • Jun 2016
        • 537
        Ok, so it seems to work with aan app-password.
        The thing is, the password is not beeing saved in the user account on the Sharp copier.
        Cache User information is enabled,
        Store user authentication information for External Connect also enabled.
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          It will only remember the password for sharepoint if you have a user code to log into the machine (as i remember) and will not work in device account mode unless a bit switch is changed to allow the machine to remember the credentials in device account mode.
          Sim 55 -03
          SW45-1
          SSO Cloud support using Device Account mode:-
          0 = Disabled (Default),
          1 = Enabled
          This is from a cr5 machine, so may work
