Disabling DHCP
  • nobody-here
    • Mar 2008
    • 237
    Disabling DHCP
    Hi there
    anybody does know it there's a Switch or SIM to disable DHCP in Wireless AccessPoint Mode?
    No clues into the tech manual.
    VDM
    29 rouge unpair manque.... cous cous....
  • sharphead
    • Aug 2009
    • 285
    Re: Disabling DHCP
    System settings- Network settings- Wireless settings- Access point mode
    • nobody-here
      • Mar 2008
      • 237
      Re: Disabling DHCP
      Thank you for your reply, but in that position is not possible to "disable DHCP"
      You can olny set IP address range, that is actually set to release "1" in order to get no one connecting.
      But I eventually need to disable DHCP fully, even DHCP server from MFP.
      • Hansen88
        • 1053
        Re: Disabling DHCP
        On the machine I am working on-A 3070 I can turn on wireless access mode and the dhcp is right below that. It is allowing me to disable it.
