Sharp MX-M850 Not Switching On
  • Khumz
    • Feb 2020
    • 63
    I have a Sharp MX-M850 that do not switch on. Actually this machine has not been working for a while, i mean years. So i want to bring back to life.This machine does not power on at all, not eve a light on the display. So I decided it is better to come up with a complete set of tested and properly working circuit boards. To my surprise same problem remains, machine do not switch on at all. Any ideas on how to resolve this problem.
  • chubblies
    • Jun 2011
    • 155
    Re: Sharp MX-M850 Not Switching On
    Are you using both power cords? And is the main switch inside front cover on? You need to meter up the various sections to see where power is getting too, but if you don't know what you are doing, walk away as you could get a shock if you touch the wrong thing
    • mojorolla
      The Wolf
      • 2614
      Get out your voltmeter and start with AC power in, then DC power out of the power supply unit.
      No simple fix for this scenario.
      Hercules 1, she's a bit of an older girl......
      • Khumz
        • Feb 2020
        • 63
        I repaired main power supply board, all DC power now available. I cant get AC across CN6 on AC PWD. I think i missing something somewhere. When i switch it on nothing happens, not even a clicking sound from a relay. I m trying to figure out switching sequence.
