F1-22 Error Code
  • ron67601
    Guest replied
  • Sharptech0892
    replied
    Re: F1-22 Error Code
    I was wrong, thinking of a different code, f1-22 is referring to the assist motor, which pushes the paper out onto tray after being stacked or stapled. Fnm5 motor
  • ron67601
    Guest replied
    Thanks for replying to my post. Are you referring to the gears on the paddle drive unit on the front frame. The ones where the clutches are? If you could supply a picture and part number I would appreciate it. Thanks Ron
  • Sharptech0892
    replied
    What I found was two gears that drive it don’t mesh together (to much gap) I was able to bend the shaft the gear is on, which fixed the error code.
  • ron67601
    started a topic F1-22 Error Code
    F1-22 Error Code
    Has anyone experienced F1-22's on these new BP-FN11 finishers? I've been having some problems after installing them in the field. One was shortly after install and the other a few months down the road. The one after install was under warranty so I was ok on that one. The other one I removed and put in a BP-TU10 till I figure this one out. I can't find the part number for the sensor FNPS7. Can the ASM-Return Paddle cause this also? Thanks for the help in advance. Ron
