Sharp MX-M464 Blank Screen
  • irdicheku
    • Aug 2019
    • 17
    Good day people.
    Anyone have ever come across this problem? It always happen when I try to replace a new control panel UI, already swap the flat cable, unplugged and connect back the oricon pwb. Even swap the sd card and hdd. Any solution that can assist my problem. Any advice is greatly appreciated. Thanks
    Sent from my SM-A536E using Tapatalk
  • driving lots of miles
    • Jun 2016
    • 399
    Re: Sharp MX-M464 Blank Screen
    If all your connections are good you need to replace the LCD panel. This is not an unusual problem for this old machine.
    • chatkal
      • Aug 2015
      • 47
      Originally posted by irdicheku
      Good day people.
      Have you checked input and output voltages on LVDS?
      • irdicheku
        • Aug 2019
        • 17
        The LCD panel is actually new. We tested on another machine before we replaced it at customer. Thanks for the feedback.
        • irdicheku
          • Aug 2019
          • 17
          I haven't tested it yet. I will try to check though. Thanks.
          • lky1978
            • Mar 2009
            • 483
            blown mirco fuse on the scn board
            • Noblemen
              • May 2023
              • 10
              The SD card might be corrupted, get a new one to replace it. One of the flat cable pin might have pealed off, in most cases the flat cable pin tips is folded. Replace.
