Constant rebooting in MX 4112
  • Noblemen
    • May 2023
    • 10
    How do I fix constant rebooting or restarting in my MX sharp 4112 colour copier?
  • chatkal
    • Aug 2015
    • 47
    Re: Constant rebooting in MX 4112
    First try to update firmware in CN mode. If it won't help replace SD card.
    • WackyJack
      • Feb 2021
      • 82
      If you have it connected to the network, it might be a corrupt print job. Try turning the machine off, removing the network cable, and booting up again. If it comes to ready and doesn't reboot, you have a print job stuck in queue on your network. If it continues the reboot loop, your best bet is probably the SD card. Although, I usually see them get locked up during the boot process if the SD card is faulty
