BP50C26 Sharp H4-00
  • Trompeter
    • 38
    [Error Code] BP50C26 Sharp H4-00
    Are there already several people who have had problems (H4-00) with the new line of Sharp BP50Cxx?
    Apparently this line is very sensitive to fluctuations in the main voltage. We had an example with a recurring H4-00 message, where we switched boards. Finally opted for a replacement machine which also gave an H4-00 message.
    After moving the Sharp to a separate voltage group, the problem was solved. At the previous location, the Sharps were connected to a group where several large machines were also connected, which always caused a fluctuation in the voltage.
  • ron67601
    Re: BP50C26 Sharp H4-00
    I had a BP-50C45 throw an H4-00 and it ended up being the PCU PWB. Mine would never work no matter where it was plugged in at. Hope this works better than the LOUSY BP-FN11 finishers.
