BP-60C45 jam printing labels
  • kyove
    • Apr 2015
    • 62
    Hello Guys,
    I have a customer who prints labels. About 50 sheets per day.
    I gave istruction to print labels (A4 sheets) only from bypass and set paper type to "labels".
    Lately every day is a jam. Label sheet rolls up in PS unit and sometimes a label goes to transfer belt.
    For me is a nightmare, I have to go to customer and clean the printer every time.
    I've already replace PS unit but nothing change.
    What can I do? I came from Kyocera world so these are one of the first Sharp in the field.
    Thank you in advance,
    Kyove
  • chatkal
    • Aug 2015
    • 47
    Re: BP-60C45 jam printing labels
    Originally posted by kyove
    Hello Guys,
    Kyove
    I hope you checked that those labels were for copiers, not inkjet and labels were not old? I'd test printing labels on heavy paper to see if it jams.
    • Hansen88
      • 1056
      Most customers have printers also and we recommend that they print labels in a printer due to all the damage they can cause in a copier.
      • kdr363
        • Apr 2019
        • 63
        make sure they are using landscape orientation, not portrait.
          • 8144
          Assuming 50 sheets of 10 labels per day = 500 labels per day or 12,500 labels per month.
          They should have a dedicated plain paper label printer using printer ribbons. Such a device is likely less expensive per label to operate especially if the labels are 100% black.
          • austonrush
            Sharp & HP Tech
            • 234
            if the labels are actually one single sheet sized at 8.5" x11" then I'd recommend a lexmark MS725dvn printer.
            If they are smaller then get a proper zebra type thermal transfer printer in there!
            You're asking for trouble running labels at volume through a copier!
