MX-Mx071 - Bypass setting
  • nobody-here
    • Mar 2008
    • 237
    [Misc] MX-Mx071 - Bypass setting
    Hi everybody
    i am having trouble with bypass settings.
    I can't "save" paper format on it.
    Even if I set it on admin page, after a while, it comes back to "auto"
    I need to fic a specific paper size and keep it there without changing it every time I need to print.
    Any issue on that?
    Thank you
    29 rouge unpair manque.... cous cous....
  • driving lots of miles
    • Jun 2016
    • 399
    Re: MX-Mx071 - Bypass setting
    Originally posted by nobody-here
    Hi everybody
    Any issue on that?
    Thank you
    You need to go into tray settings on the copier to make the change permanent. However, if other people are using the tray for other sizes and types it will cause issues for them.
    • bilyahn
      • Dec 2006
      • 1470
      Also anytime someone puts paper in the bypass tray a popup menu shows up and it is very easy for someone to change the settings without even realizing it. I haven't found a way to disable this message.
      Good luck
      Bil
      • boutn
        • Jun 2016
        • 547
        Good luck
        Bil
        system settings - common settings - paper tray settings - untick "display paper tray settings when bypass tray detects paper"
        • boutn
          • Jun 2016
          • 547
          Hi everybody
          Any issue on that?
          Thank you
          I presume its a custom format?
          You can make your custom format, go to copy, select that custom format on the bypass tray, save it as a shortcut on the homepage.
          That way you can quickly switch to your custom format.
          • nobody-here
            • Mar 2008
            • 237
            Thank you
            I will try everything you suggested.
