A0-30 error clearance.
  • Noblemen
    • May 2023
    • 10
    [Error Code] A0-30 error clearance.
    How do I clear error code A0-30 in MX b201d copier?
  • bilyahn
    • Dec 2006
    • 1470
    Re: A0-30 error clearance.
    This is a configuration error, which normally means a board mismatch. Did this just happen out of the blue?
    • mojorolla
      The Wolf
      • 2624
      Print out the 22-6 and check the soft switches for the scanner. I have had a few instances where all 8 bits of all the scanner switches change to 1 from the default of 0
      This can generate A0 errors with SCN board changes or corrupted firmware.
      • Noblemen
        • May 2023
        • 10
        Ok I do appreciate your contributions I shall reply as I carry out your suggestions thanks.
