MX-3050N no yellow
  • bigdaddyooo
    • Dec 2014
    • 212
    MX-3050N no yellow
    Drum is coated with yellow toner when doing a 64-1 pattern 9. I have no transfer from drum to TC1. I have replaced MFP pwb, PCU pwb, TC pwb and TC1 unit. Still having the issue. I swapped Y and M drums, still have no yellow. Any ideas?
    Are you the police? "No ma'am, were musicians"
  • DAKOTADAN
    • Jan 2011
    • 61
    Re: MX-3050N no yellow
    1. Do a CN update, this fixes alot of goofy issues for me.
    2. Try a different working y-dev unit. And check the connections on the rear of machine that contact the t1 belt unit, especially around
    the y lift area.
    Good luck.
    Dan
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      Does it work on copy mode? i had something similar where as print was missing a channel and copy was ok. Sim 67-17 sorted this for me, odd one.
      Networking skills are advantageous but use of a 3m vacuum cleaner is essential
      • bigdaddyooo
        • Dec 2014
        • 212
        Re: MX-3050N no yellow UPDATE
        I started getting 1/2 yellow from top to bottom so for shits and giggles I replaced the LSU unit and VIOLA....fixed. Thank you guys for the suggestions
