Hello Everyone,
I've got a MX-3070n that originally was called in for CYM colors being offset. At first we tried clearing the LSU data and attempted to re-calibrated, but the LSU numbers wouldn't stay in the 50s. We swapped the LSU from another 3070n over to the current one and the problem persists. The following things we've done so far during troubleshooting process was; we swapped all the drums, primary and secondary transfer over from an identical model, updated the firmware, and replaced the SSD for a history of E7-A7 code. When we performed sim 50-22 and made the L and R screw adjustments, the device would throw "Data_Main_K_F_1st 50" resulting in an incomplete process. I've reached out to Sharp help desk and they were stumped as well. Google search only showed 1 result posted here in 2018 that went unanswered. and the closest thing I found something along the line was "Data_Sub_..." but it's for an older model. This error code isn't listed in the manuals or anything related in the tech bulletins. Has anyone ran into a similar issue? Any input is greatly appreciated.
