SMTP "other error" on connection check
  • sharpie
    • Feb 2011
    • 182
    I have a MX-2640 that we supplied a client for a short term rental that won't scan to email giving an "other error" on connection test. They have an old MX-M283N that scans properly and the client has an internal mail server on their network. The network settings are identical and all firmware has been updated. I can ping back and forth from both machines and to the router. We have checked the router for any MAC address filtering or other impediment to the newly introduced machine. I have never encountered the "other error" on a SMTP connection test and hope someone can provide some insight. Thank you.
  • tedtech
    • Dec 2011
    • 50
    Re: SMTP "other error" on connection check
    Wasn't there a firmware that allowed for SSL 2? Might be worth a look.
    • havokprod
      • Oct 2012
      • 159
      Ver 6.00.A2.I0 SMB v2 and TLS 1.2 is the one you are thinking about.
      • mansart
        • 852
        • CroceL
          Sharp / Brother Tech
          • Jun 2020
          • 62
          DEA-4410_Firmware_support_status.pdf
          Like others said check if the firmware with TLS support is installed , the MX-M283 is most likely already up-to-date
