MX-M4070 reset admin password issue
  • nathansipe
    just another tech
    • Aug 2009
    • 122
    This is the first admin reset I've had to do on this model series. I went through the sim 4 6 3 // and submitted the code to Sharp. They got back to me with the reset code. After I input it into the reset screen and press execute, the execute box goes gray with no other message. I can hit ok and go back to the main copier screen. I put in admin to get into the network settings and it's still failing. When I go back into the 4 6 3 // reset screen, the text box for the reset code is still grayed out. Almost like it's still processing but it tells me nothing.
    How long does the reset usually take? The Sharp document says it will give me a message of request successfully processed or failed. It's giving me neither.
    It's been like this for about 10 minutes.
    Any ideas?
    Best rule for troubleshooting.
    K I S S Keep It Simple Stupid
  • EasyRider
    • Jan 2015
    • 85
    Re: MX-M4070 reset admin password issue
    Using a thumb-drive, you could do a SIM 56-2 Export Copy HDD from a similar model, I use a MX5141, it doesn't matter.
    Sim 56-2 import HDD to your MX-M4070. Simple, easy, works.
    • nathansipe
      just another tech
      • Aug 2009
      • 122
      Thanks EasyRider. I didn't realize it was that easy. Worked like a charm. If I would have known that, I never would have went through Sharp to have it reset.
