U5-30 Code
  • Leebs14
    • Feb 2014
    • 457
    [Error Code] U5-30 Code
    I have a U5-20 (NOT 30) error on a MX5070 which is miles away, after speaking with the customer, the tray lifts the original up to the feed rollers but it then doesn’t do anything and throws the error. I’m thinking probable paper pick up/paper feed drive motor but could it be the board?
    anyone have experience of this error
    thanks
  • mloudy
    • Oct 2015
    • 784
    Re: U5-30 Code
    We have not seen a 30 but we have seen several U5-20. I would take an ADF pwb. First look for paper clips or staples laying on the pwb. You might just be able to remove them if they are there and it will clear. Also make sure you cover the area in the rear frame of the ADF where clips and staples can fall through.
    Could also be the the ADF doesn't know when the original tray has lifted. Not sure what arm or sensor that is.
    • Leebs14
      • Feb 2014
      • 457
      Re: U5-30 Code
      Thanks, you are right, it is a U5-20, I will order a board, would you order a motor, or do you think it is more likely to be the board
      • mloudy
        • Oct 2015
        • 784
        Re: U5-30 Code
        Our records show we have had five of these. Four of them we cleared and updated the firmware. One of them there were two paper clips on the pwb which required a pwb replacement.
        There is a bulletin about replacing the ADF pwb and then getting a E6-11. If this happens you will also need to change the ADF CCD to a new style. This might only be for the MX-xxx1 series though.
        • EasyRider
          • Jan 2015
          • 87
          Re: U5-30 Code
          What mloudy said!
          Paperclips and staples are a big cause of these.
          The paperclip can be very hot to touch, but the board will still function after removing the paperclip!
          • nanohitmen
            • Apr 2019
            • 115
            Re: U5-30 Code
            I began plasti dipping boards to avoid the whole paperclip fiasco. Was happening way too often
            • JLSam
              • Jun 2015
              • 605
              Re: U5-30 Code
              My records show I have had 2 of these, both on 3070's. Each one resolved with removal of jammed media. Each one I reflashed firmware.
              The the above mentioned though, always check to see if there are screws, paperclips, and staples that are touching the ADF board...
              Good luck.
              • Dark Helmet
                • May 2009
                • 847
                Re: U5-30 Code
                If you order the board don't forget the DF white calibration sheet Adjustment 14A2.
                • onetek
                  • 318
                  Re: U5-30 Code
                  I am dealing with a 4071 throwing U5-20 random , never when I am there. Sims motors and sensors checks all ok.. Already replaced board ,sensors, clutches. Got to go back today with main adf motor (was on order)....
                  • Dark Helmet
                    • May 2009
                    • 847
                    Re: U5-30 Code
                    We replaced the main motor in the DF on a machine we just installed and it died during demo. They do fail!
