Sharp MX-6580 Black Lines
  • Hoosierdaddy
    • Oct 2016
    • 181
    Would someone be kind enough to let me have access to the Service manual for this machine? This machine has black lines on it and it still has 70% left on its life.
    Thanks in advance
    Hoosierdaddy
  • Imprestik
    • Aug 2012
    • 296
    Re: Sharp MX-6580 Black Lines
    swap the drum units around and see if the issue moves
    • chatkal
      • Aug 2015
      • 47
      Thanks in advance
      Hoosierdaddy
      Clean Bk MC first. Swap with any other MC to check if it causes the problem. If it is replace MX-751MK.
      Anyway, if you need the manual here you are:
      Dropbox - SM_MX-7580N_S4E.PDF - Simplify your life
