Firmware upgrade
  • Noblemen
    • May 2023
    • 10
    Firmware upgrade
    Hello people to whom it may concern, I need a step by step procedures on how to upgrade my small MX b201d copier firmware thanks.
  • jon jennings
    • Aug 2011
    • 51
    Re: Firmware upgrade
    Firmware.pdf
    • Noblemen
      • May 2023
      • 10
      I do appreciate your excellent reply of my questions, Please sir, I have further questions, the procedures given, is it for all brand of sharp copiers? Can upgraded firmwares correct the error code A0-30, U2-00 and the likes? Where can I get the matchable firmwares to do the job? Thanks.
      • JR2ALTA
        • Feb 2010
        • 2033
        Hello, I understand you are in a difficult position. You are trying to fix Sharp copiers without much training or support. Here, we can help if you keep your questions specific to one issue at a time. Please provide details and let us know what you have already tried.
        As for firmware files, you must get them from Sharp. Any other transaction of firmware is illegal and may install viruses. The Sharp update procedure on current models is Sim 49-1
        • Noblemen
          • May 2023
          • 10
          The problem am facing now is that the mx -b201d is showing error code U2-00, and I tried to clear it but it won't clear so I thought upgrading the firmware will correct the error code, any better solution?
          • lky1978
            • Mar 2009
            • 483
            I believe U2-00 problem come from EEPROM.
            • Noblemen
              • May 2023
              • 10
              What should I do to solve the problems hence U2-00 is caused by eeprom?
