Sharp MX2300N Call for Service code F2-64
  • ILRTech
    • Jun 2025
    Hi,
    Our Sharp MX2300N printer displaying a "Call for Service" error message. The code given is F2-64. Does anyone know what this means?
    Thanks,
  • johnbla
    • Apr 2005
    • 94
    There is a problem with the Bk Toner supply.... check the End Seal was removed on the Cart, if not that, then call a Tech.
    regards
    John
    sigpic
    " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
    • ILRTech
      Thanks. I'll check it out.
      • OMD-227
        Johnny, you are right......... as always.
        Most likely seal tape still on cartridge or possible blocked toner down-pipe.
        Yes, call your local tech if checking the cartridge & a restart of the machine fails to correct your issue.
        • johnbla
          • Apr 2005
          • 94
          regards
          John
          sigpic
          • ILRTech
            So I checked out the bk toner cartridge and there were no obvious problems.
            I put the an old, used bk toner cartridge back in and restarted the printer. Once all the codes cleared, I removed the old bk toner and put back the original bk toner I had removed.
            That seemed to fix it. The printer is working fine now.
            Thanks again for all your suggestions.
