Sharp AR-M350 Error Code PC
+ More Options
Posts
  • Tech2002
    • Aug 2008
    • 334
    Have a client that has the Code PC come up twice today. One time it came up by itself then they had a power outage and it came up again. It's under Surge Protection. It has cleared itself both times. I get it that from the Service Manual it is - "Personal Counter not Installed," then referring to the Controller.
    My suggestion to the client to offer something was to shut it off, un-plug unit from the wall and turn it back on.
    Any other more professional suggestion? I have never seen this happen before.
    Thanks.
  • OMD-227
    On the Scanner PWB, check the CN5 enable loop is fitted.
    Check sim26 for PC/Auditor setup disabled if you are not actually using a counter.
    • Tech2002
      • Aug 2008
      • 334
      I appreciate the reply.
      It was suggested too, that I go SIMMS 83-2 to clear out the Control PWB. I did this - Jury is still out as to whether it worked or not. However, if not, I will try your suggestion.
      Appreciate the response.
      • Tech2002
        • Aug 2008
        • 334
        wazza - you were right on with your suggestion. N5 Loop Connector was slightly disengaged - when I pushed it down in place - no more PC Code.
        Somethng so simple to overlook caused an issue. Good to go - Thanks.
        • OMD-227
          Sweet brother!
