HDD Raw copy too use
  • Hansen88
    • 1046
    I have used this a lot and in general it is real easy to use. I am wondering what other people do when your source and target show the exact same info, so you cant tell which one is source or target. Thanks
  • copiertec
    • Jan 2016
    • 2186
    Re: HDD Raw copy too use
    Unplug one source, then plug it back in and mark it.
    • Hansen88
      • 1046
      Thanks for the reply. That does not work. I put one msate with different specs so the two show differently. Even if I swap them in the usb ports the order on the screen does not change. Also when you unplug one it does not change on the screen, you have to close the program and open again. Have not found a way to change the name of one of them.
