sharp AR 235
+ More Options
Posts
  • xeroxsharp
    • Nov 2008
    • 270
    sharp AR 235
    AR 235 : When power on the copier,sometimes got E7-11 or F5-02 and sometimes it is READY TO COPY. Allredy replaced flat cable (new) and scaning assy from another copier,but stil not good. Any ideas,because I will order first new scaning assy not only scaning lamp. Thanks
  • igi
    • 1507
    hi there
    the reference white plate is good to replace for this errors you getting.
    try this
    good luck
    • xeroxsharp
      • Nov 2008
      • 270
      1. Replaced scaning assy,fixed only E7-11,but still got another error code sometimes when I powered copier.
      2. Replaced lens-not with new one,adjusted it,and it works fine
      PS: This was a damn job!!!!!!!
