Sharp MX-B455W error F2-40
  • txonsov2
    • Aug 2023
    • 18
    Hello, you see, whenever the error f2-40 has appeared in these models we have always changed the whole DV unit and it was solved but in this case I changed the DV unit for a new one and after 4 days the error continues to appear again, I don't know if anyone has had any problem of this type and you can help me.
  • jp74msj55
    • Oct 2014
    • 149
    Re: Sharp MX-B455W error F2-40
    I have had these a few times. Make sure the unit has new toner lock modification installed.
    • CroceL
      Sharp / Brother Tech
      • Jun 2020
      • 62
      Check the drum unit, sometimes a little bit of paper gets stuck to the drum on these models and pulls out Developer.
      Had the same just 3 days ago
      • ricohrice
        • Dec 2008
        • 42
        I had one ended up being the DCPS pwb.
        • txonsov2
          • Aug 2023
          • 18
          Thank you very much with your answer, as the new toner modification, do you mean a bulletin for the machine, or a modification of the toners.
          Thank you for your reply.
          • mloudy
            • Oct 2015
            • 787
            The little horseshoe shape bit at the rear of the copier that locks the toner cartridge in. If you remove the toner and look into the opening you will see it at the back. There is a bulletin.
            • mloudy
              • Oct 2015
              • 787
              New style
              • txonsov2
                • Aug 2023
                • 18
                Originally posted by mloudy
                New style
                [ATTACH=CONFIG]60595[/ATTACH]
                Thank you very much for the visual input, with this I will order the part and replace it, thank you.
                • Sask1967
                  Senior technician
                  • Jun 2023
                  • 7
                  txsonov2, does the toner lock fixed the F2-40?
