MX-B467P with toner spots
  • OlliK1969
    • Nov 2016
    • 311
    Hello
    We have more than 25 pieces of MX-B467P available to one customer. Now, after about 20,000 pages, toner spots appear on the edges of the first one. They can be removed, but that's not the point. The paper is of very good quality and we only use original toner. Has anyone had something similar?? Thanks
  • JLSam
    • Jun 2015
    • 605
    Re: MX-B467P with toner spots
    Originally posted by OlliK1969
    Hello
    I just realized that no one responded to your post.
    I looked up this printer, and it's a lexmark rebrand. Honestly, I would look for it's original model name, and ask the Lexmark forum for help.
    • mloudy
      • Oct 2015
      • 791
      Lexmark M1246 I think.
      I have not seen this issue.
      • JR2ALTA
        • Feb 2010
        • 2033
        what do you mean 'They can be removed"? Do the toner specs simply wipe off? To me, that would mean they have not been fused and you have exit section that needs cleaning. Maybe you can increase fuse temp within "plain" paper settings...
        I don't believe this fuser has envelope levers.
        • OlliK1969
          • Nov 2016
          • 311
          Hi
          Sharp sent us a new fuser unit in exchange to look at ours. And there is a new firmware that cannot officially be accessed on the Sharp server yet. Unusual
          • mloudy
            • Oct 2015
            • 791
            Lexmark is really good at listing every change that is included in a new firmware. I have only seen Sharp at the same firmware level as the Lexmark one time.
            As a Lexmark dealer we can often access something called PE firmware which hasn't been released yet and Lexmark will list all the changes. It is one area they are very good at. New firmware was just release in the last few days. MSNGM.230.041
            • OlliK1969
              • Nov 2016
              • 311
              Hello
              Yes, this is the version that was made available to me via drop box from Sharp
