Sharp MX-6240N Power supply Board
  • FADNAS
    • Jan 2024
    • 3
    [Electrical] Sharp MX-6240N Power supply Board
    Dear All,
    I am encountering a power issue with the Sharp MX-6240N copier and trying to reach to a schematic diagram for the power board. I have donwloaded the service manual and despite all models covered in the service manual I wasn't able to find the one matching the power board I have. The reference number of the power board is RDENC0144FCPZ, I am ready to send you any required information and even photos to help finding the suitable schematic diagram and repair the board. (Please note that the machine origine is UK just for reference).
    Please advise.
    Thank you and best regards.
    Fad
  • mloudy
    • Oct 2015
    • 771
    Re: Sharp MX-6240N Power supply Board
    This model has seperate manuals for the Circuit Diagram and Actual Wiring Diagram. I think you will want the UK version of the Circuit Diagram manual.
    • FADNAS
      • Jan 2024
      • 3
      Literally yes, do you have any references from which I can download these manuals from.
      I appreciate your support.
      Regards,
      Fad
      • chubblies
        • Jun 2011
        • 154
        Sharp do not provide actual board circuits anymore, they only provide block schematics.
        There are a few soldered fuses (genius Sharp, irreplaceable fuses) on both the AC and DC psu's, I would start with those as that should be an easy fix if blown. here are the schematics and part codes anyway
        MX6240-7040_SM1.pdf
        MX6240-7040_SM.pdf
        • FADNAS
          • Jan 2024
          • 3
          [ATTACH=CONFIG]61211[/ATTACH][ATTACH=CONFIG]61212[/ATTACH]
          [ATTACH]61213[/ATTACH]
          [ATTACH]61214[/ATTACH]
          Thank you for the documents, all fuses are ok I just need to have the schematics for this model since I need to know the details of the conncetors to figure out if there is any feedback from any other external component that should be received so the 24VDC volt will be initiated accordingly. How come all models schematics are available for this model but not for the UK version. Unfortunately all provided documents doesn't match with the board I have. The number of the connectors and number of pinouts are not matching. I'm really stuck, the only way is to find the relative schematics to proceed with the reparation.
          Regards,
          FAD
