sharp mx 6070
  • LEOMARTINEZ
    • Jan 2024
    • 6
    sharp mx 6070
    have a problem with a sharp mx m6070 it consistently shows the code f2-78, I know from experience that this is the image density sensor and in other models such as the sharp 565 I know that it is located on the transfer roller, but it is not I know where it is so I can clean it or change it. Could someone help me with its location?
  • Sven94
    • Sep 2023
    • 28
    Re: sharp mx 6070
    Also do a FW Update DEA-5211_ARE1351.pdf
    • boutn
      • Jun 2016
      • 547
      Re: sharp mx 6070
      2 sensors (front and back) above the transferbelt on the right side.
      If you remove the transferbelt unit, you can see them.
      • jp74msj55
        • Oct 2014
        • 149
        Re: sharp mx 6070
        Do what boutn stated. Easy to clean. Have cleaned but never replaced for this code!!!!!!
        • LEOMARTINEZ
          • Jan 2024
          • 6
          Re: sharp mx 6070
          my mistake the model is mx 6500 sorry
          • hellcat
            • Jan 2012
            • 124
            Re: sharp mx 6070
            ive had to replace a few of the sensors before, I was unable to find them in the parts manual so stole them out of a junker we had. I would think it would be the same problem even on a MX6500 as they are very similar machines.
            • tedtech
              • Dec 2011
              • 50
              Re: sharp mx 6070
              Clean that sensor really good with alcohol, I've had several machines that constantly threw that code and since using alcohol to clean I haven't seen it come back.
              • Sharptech0892
                • Aug 2011
                • 78
                Re: sharp mx 6070
                Also run 44-2, it will show the sensor that has a issue(will get err message)
