P_ON jam code won't clear
  • Doyle
    • Nov 2016
    • 7
    [Error Code] P_ON jam code won't clear
    I have a BP-70C55 with an FN13 1k finisher in the shop with a P_ON jam code on the APEX sensor in the finisher. I have upgraded the firmware and replace the photosensors in the finisher, but the code won't clear. When I go into SIM mode to find the jam/error code none is reported so there is nothing to clear out. Any ideas because I am stumped?
  • Hart
    • Feb 2024
    • 376
    Re: P_ON jam code won't clear
    Open and close all doors.
    • jp74msj55
      • Oct 2014
      • 146
      Do the jogger front and rear at power up go back and forth to home position? mine was a FN16 and
      Repalced process tray unit for the finisher. Thought originally front jogger sensor was bad but ordered
      whole unit and worked fine after that. Believe jogger motor had a bad spot in it but wasn't that expensive and
      ordered whole unit and not real difficult to replace. Good luck.
