ar 336
+ More Options
Posts
  • hector
    ar 336
    code F2 00
  • countrytech
    • Mar 2009
    • 68
    I think you will find that relates to the foam toner roll in the dev tank needing replacement. It will be adding too much toner.
    • MHeon71
      • Oct 2008
      • 489
      He is correct. The foam toner roller in the toner hopper may be worn. You should see an obvious wear mark at the end of the roller. You will want to replace the developer when you replace the toner roller. There is a bulletin on the issue.
