arm 350 exposure
  • pontiac
    • 420
    arm 350 exposure
    Just wondering if there is seperate exposure adjustment for the top scanner. Thanks
  • ZOOTECH
    Senior member of CRS
    • 3375
    Test Command 46-20 can adjust DSPF (used so that copy density is the same for OC and SPF).
    • Dark Helmet
      • May 2009
      • 835
      You can also bump it up a bit from the Key Operators in the COPY functions seperatly.
      • mtech
        • Mar 2007
        • 307
        Odd and even should be adjusted to the same number. 46-18 should adjust the gamma. You may need to adjust this if you need to have a larger cut off between white and dark, But be careful if you adjust the gamma setting-check all exposure modes!
        • pontiac
          • 420
          EXPOSURE
          Thanks everyone , sim- 46-20 did it.
