AR 161 Simulation
  • vstar
    • Aug 2007
    • 176
    AR 161 Simulation
    Hi everyone,
    I need to enter sim on this model to reset a fuser code. The fuser is fine, we had some storms come in and I believe it just got zapped.
    I was wondering if getting into sims is the same as an ARF 152 (C-exp select/C-exp select)? If not could someone please let me know.
    I know I need to reset sim 14, just not sure how to get there.
    I am more familier with the 287 models.
    Cameron
  • ZOOTECH
    Senior member of CRS
    • 3374
    I believe it is C - Int - 0 - Int, but the original service manual says otherwise.
    • vstar
      • Aug 2007
      • 176
      Thanks zootech, I will try that.
      What I posted earlier did not work.
      Cameron
      • oldrn
        • 166
        Zootech is correct on the code, you are correct on the storm, power fluctuations as a cause, happens a lot on these.
        • vstar
          • Aug 2007
          • 176
          Thanks everyone, I was able to reset the code.
          Thanks again
          Cameron
          • adel_nagieb2000@yahoo.com
            • Jun 2009
            • 14
            Originally posted by vstar
            Hi everyone,
            Cameron
            simulation for ar 161 is C-PAUSE-ZERO-PAUSE
